Engine lid strut
Started by Chilli Girl, July 12, 2021, 18:53
Chilli Girl
It just came off in my hand officer :o   Someone in the past has attempted to put superglue on it but it finally gave way this evening.  It's a plastic circular trim that fits flush to the bodywork - does anyone have any other ideas other than using glue again to fix it.  Before anyone mentions get a gas strut one, I'm not interested in that mod - this little car has had more mods in the past than tanks of fuel and I just want to get her back looking the way she should.  Here's a pic.  I've removed it entirely now and cleaned off all the old glue too.
Quote from: Chilli Girl on July 12, 2021, 18:53It just came off in my hand officer :o   Someone in the past has attempted to put superglue on it but it finally gave way this evening.  It's a plastic circular trim that fits flush to the bodywork - does anyone have any other ideas other than using glue again to fix it.  Before anyone mentions get a gas strut one, I'm not interested in that mod - this little car has had more mods in the past than tanks of fuel and I just want to get her back looking the way she should.  Here's a pic.  I've removed it entirely now and cleaned off all the old glue too.
Mr Dick Sloane our Breaker on here would be my thought for a replacement. Plastic materials can seldom be mended once broken.
Chilli Girl
The plastic doesn't seem damaged just to small for the bodywork hole as such.  Therefore, it just spins around :o
Chilli Girl
Perhaps I need some sort of narrow tape around the central part to make it bigger, that way it would fit better?
jonbill
I think the real problem is that the metal is slightly deformed. I think it needs clamping with a thick washer either side. maybe we could have a go next meet up?
Chilli Girl
Are you saying I've got a deformed car? ;)  ;D   Joking aside though, I think Foxy's was abit the same, it never came out but was abit loose always.
jonbill
Quote from: Chilli Girl on July 12, 2021, 19:36Are you saying I've got a deformed car? ;)  ;D
only slightly, in a charismatic sort of way.
The plastic loses it's flexibility over countless heat cycles and shrinks away from its expanded size at time of fitting.
Chilli Girl
I live and learn, didn't know that John, thank you. ;D
paulj
Andrew Henderson at J Spec found an odd plastic clip for me which is not made as a pattern part any more.  I'd suggest sending the photo to him and asking for a solution.   Your either need a new assembly or just the plastic bit. They are a relatively new breaker but very helpful.
Today
In the late 1980's
They're available on ebay but I wasn't confident enough in the sizes to add the link here.
ptennisnet
I confess to aralditing mine in place
Beachbum957
---------- Support Rod Grommet (F)
90480-15024
---------- Support Rod Grommet (R)
90480-15028
