Roof adjustment.
Started by Chilli Girl, July 5, 2021, 18:12
Chilli Girl
Well after leaving DD on Saturday lidless, within 8 miles I had to stop to put the roof up.  I had great difficulty getting the passenger side roof clip to shut, it was almost too short to reach? Anyhow after a struggle I did get it shut!  Is there an adjustment to make it slightly looser and easier to close.  It's only the passenger side that is difficult!  I appreciate it needs to be snug though. :o
Quote from: Chilli Girl on July  5, 2021, 18:12Well after leaving DD on Saturday lidless, within 8 miles I had to stop to put the roof up.  I had great difficulty getting the passenger side roof clip to shut, it was almost too short to reach? Anyhow after a struggle I did get it shut!  Is there an adjustment to make it slightly looser and easier to close.  It's only the passenger side that is difficult!  I appreciate it needs to be snug though. :o
The OE hood being a plastic material is greatly affected by temperature, when warm it is bigger and more flexible. When cold smaller and less flexible. The angle of "attack"from the driver's seat is more direct on that side than the passenger side. So, I suggest that these factors combined to make closing that side more difficult. I still find that my hood is easier to operate at times and less than easy at others. But when the conditions are right it is easy to open and close.
I suggest always leave the hood up and latched when garaged, park the car in the sun , or run the heater before dropping and persevere when raining and closing as it will be then it will test you the most!
Iain
Theres a nut, 10mm i think, under a plastic clip on the main clasp which can be adjusted to tighten or loosen the clip.
When you put the hood up, check that the wired edges are going into the channel on the side of the roof.  They tend to pop out when you put the roof down (which is good as that puts less strain on the fabric).
If the wire in not in place- the roof will be harder to fasten.  Just guide them into the channels and then finish fastening the roof.
fawtytoo
If the clamp needs adjusting, there's a YouTube video that shows how. He adjusts the side clamp but they all adjust the same way.
Chilli Girl
Brilliant thank you ;D
Chilli Girl
Adjusted whilst sat in passenger seat eating my lunch at work today. All sorted. Thank you all.  ;D
fawtytoo
Quote from: Carolyn on July  5, 2021, 18:41When you put the hood up, check that the wired edges are going into the channel on the side of the roof.  They tend to pop out when you put the roof down (which is good as that puts less strain on the fabric).
@Carolyn
I'm not sure what you're referring to there. Could you clarify please?
The arc of the roof that fits over the window has a heavy wire sewn into it's edge.
When the roof is up, that edge should sit in the narrow channel that is attached to the edge of the roof, and also arcs over the window.
I'll see if I can take a couple of pics tomorrow.
