I’ve lost my Numberplate can you help
Started by s12vea, July 2, 2021, 18:32
s12vea
Made the 220 miles in the sun to cloudy wales but seem to have lost my rear numberplate on route.
As I haven't got my v5 I'm unable to get another made for my return trip tomorrow, has anyone travelling up tomorrow got :-
Any rear number plate
Paper
Black marker pen
Tape
So I can make something up to help me get back legally
TF204 Blue
Another one won't hurt  .....
Do demon not do plates.
Tell them just a show plate. No v5 required?
s12vea
Quote from: Ardent on July  2, 2021, 18:59Do demon not do plates.
I did think about show plate option. It always worth an ask
TF204 Blue
paulj
...or perhaps you didn't loose it till the journey home.
Today
In the late 1980's
Quote from: s12vea on July  2, 2021, 19:02
I think it's your best bet.
s12vea
Quote from: paulj on July  2, 2021, 23:21...or perhaps you didn't loose it till the journey home.
I didn't realise officer
TF204 Blue
paulj
Quote from: s12vea on July  3, 2021, 06:42
Number Plate officer, wheres my caravan?
Today
In the late 1980's
s12vea
TF204 Blue
I think you did a great job so no need to bother getting an actual replacement.
s12vea
Quote from: Topdownman on July  4, 2021, 18:04I think you did a great job so no need to bother getting an actual replacement.
Thanks for the help securing the masterpiece to the car
TF204 Blue
Frank Rabbets
Just had to cut through the original 06 double sided tape with a flexible steak knife. I needed to take the rear off just to clean up and check round. I used double sided tape to fix back on but not knowing the tapes quality I used 2 self tapers as a back up.  12-15mm max long is enough to get through plate, tape and back plate and without coming up against the structure behind.
I had a land cruiser plate fall off in France. Just parked up fortunately so did not lose the plate. I had to drill 2 holes to line up with the captive nuts in the tailgate which they should have used. Took me 1 1/2 hours to drill through with a screw driver!!
puma2
 ;D i took your number plate just in case my exhaust went missing ;D  ;D
hope you get it sorted soon and does not cause you any legal problems
s12vea
Quote from: puma2 on July  5, 2021, 11:36;D i took your number plate just in case my exhaust went missing ;D  ;D
Brilliant! I knew it was you.
Park with those exhausts close to the wall in the garage just in case I pop back to Cardiff one day this week
TF204 Blue
