Brand New Caliper Issue
Started by ty222, June 14, 2021, 19:36
With the handbrake off. Are the pads in contact with the disc? Or at least no more than 1mm gap.
How many clicks on the hand brake?
Spec is 5-8
ty222
I've just took my wheel off again and  with the handbrake adjusted as it is there's basically no return on the level it stays Asif fully open.
I have attached some pics one with Hb on and one with it off.
Also attached the brake cable I used, my 2 is a 2000 model but an import.
ty222
Quote from: Ardent on June 22, 2021, 17:33With the handbrake off. Are the pads in contact with the disc? Or at least no more than 1mm gap.
Spec is 5-8
With the handbrake off the pads are touching the disk ever so slightly and when the handbrake is fully tight on the adjustment I get 7 clicks
Quote from: ty222 on June 22, 2021, 19:05
Spec is 5-8
That is about spot on then.
Even when things are correct. Still not great.
Newbie57
I has a load of issues with mine last year. I gave up and got the local garage to do
wotugonado
7 clicks in total? As you'll need some reserve travel for the Mot test
ty222
yes, 7 in total its too hard to pull after that and still isnt on strong enough in my opinion.
fawtytoo
Can you elaborate one what you mean by "isn't on strong enough"?
Is it worse in wet weather? Can you physically push/move the car? Will it roll on a hill?
What happens if you release then re-apply the handbrake, say 2 or 3 times? Does it improve each time? I find I have to do this, particularly in damp/wet weather, but will eventually hold fine.
Could it be the pads? Poor quality/compound maybe?
Quote from: fawtytoo on June 25, 2021, 12:16Can you elaborate one what you mean by "isn't on strong enough"?
Are you pressing firmly on the brake pedal when applying the handbrake as this helps
As per the manual.
