Passenger- side Electric Window Issues
Started by Gibla, June 12, 2021, 13:16
Gibla
Not operating up or down :- not even attempting to move, so doesn't appear to be a mechanical issue.
Other than a duff fuse any quick and simple remedies offered?
Previous owner had pointed this out - his comments(abridged)
After checking fuses etc and finding no issues I continued with the switch by the handbrake and eventually by gently rocking it, the window went up so I guessed a issue with the switch itself.'
stock 2001 Dark Green MR-S (6R4)
Quote from: Gibla on June 12, 2021, 13:16Not operating up or down :- not even attempting to move, so doesn't appear to be a mechanical issue.
You are aware of the operation of the "Passenger window disable switch"  ?
Otherwise I would try temporarily stopping the switch with the drivers window. If it then works get a replacement sepwitch.
Gibla
Quote from: Joesson on June 12, 2021, 13:24You are aware of the operation of the "Passenger window disable switch"  ?
Hangs head in shame, now on the 24 hr naughty step ......it's working again!!
Many thanks @Joesson
Chilli Girl
Quote from: Gibla on June 12, 2021, 13:36
Don't worry, I did a similar thing when I got Foxy in Jan 2016, I wondered why the side vent wasn't working - put a post up on here and realised I'd got the control on "closed off" mode!  What a bl—-dy fool I felt!
Gibla
For all of my sins Jane @Chilli Girl (of which there are many) I would rather admit to errors and faux-pas rather than 'winging it' or outright denial.
ucb
After a trip out to York this week, my passenger window has also ceased to function.
There I was contemplating fuse replacements, trim removal and switch exchanges, because it is a 21 year old car and things do fail.
But I see my bubble is burst and I simply have to go out and flick another switch.....
ucb
Switch flocked and car back to perfect.....
Bloody Japanese reliability.
A friend had a Midget and a Merc W115 sat in his garage which have both spent significant time off the road. But me, no. I get bloody perfect functioning and action. When will this ignominy end????
virginpaul
Need to get rid of that daft functioning switch and use it for some5way more satisfying....
https://www.mr2roc.org/forum/index.php?topic=5453.0
