Rear caliper piston
Started by Gaz mr-s, May 15, 2021, 19:15
I bought refurbished rear calipers from Simon Sinclair last year.  I've taken the discs of for a clean-up & am trying to re-fit.
The caliper won't go over the pads. (same pads, few miles) I didn't expect to have to turn the piston in, but it wasn't going over. So I'm turning, & turning.... & I don't the piston is going back in at all.
Has anyone come across this before?
I suspect the calliper isn't fully expanded?
Don't understand what you mean C, ??
Quote from: Gaz mr-s on May 15, 2021, 19:25Don't understand what you mean C, ??
all the way out on its sliders.
jonbill
screwing alone isn't enough, you have to press too. And what Carolyn said.
Quote from: Carolyn on May 15, 2021, 19:32
Misunderstanding maybe..... sliding no problem, caliper engaging over outside pad, but piston bumping into pad backplate.  I could try more force onto it.
Are you holding the disc steady with a wheel nut?
Quote from: Carolyn on May 15, 2021, 19:50Are you holding the disc steady with a wheel nut?
Yep... two.
Very strange.
It's going to be something silly!
Take a break ands tart afresh tomorrow?
It's hard to know when it's not in front of you. ;D
Have you got the notch aligned with the nipple on the pad?
From my simplistic viewpoint the only  "adjustment " is in the position of the piston, so if the pad / disc/ pad won't fit into the caliper the piston is too far out and needs pushing back in.
Mikeymead
I'd better pay attention to this as I need to replace the rear pads soon, last time I did it I replaced both calipers so I never had to wind them back. Is the rotation of the piston handed to each side or are they the same?
Piston come to a stop, will not turn clockwise any more, but is sticking proud of the rubber seal by about 2mm.
Grumble...
Quote from: Mikeymead on May 15, 2021, 20:04I'd better pay attention to this as I need to replace the rear pads soon, last time I did it I replaced both calipers so I never had to wind them back. Is the rotation of the piston handed to each side or are they the same?
The same. Clockwise is in.
paulj
Just had a look in the Toyota factory manual - that is quite "agricultural" and suggests pushing the piston in with the handle of a hammer.
.....only the best from our main dealers!
Today
In the late 1980's
Is the nipple on the back of the pad pined up?
Mikeymead
Quote from: Carolyn on May 15, 2021, 20:11
Many thanks.
Quote from: paulj on May 15, 2021, 20:20Just had a look in the Toyota factory manual - that is quite "agricultural" and suggests pushing the piston in with the handle of a hammer.
A hammer shaft is typically wood, wood is softer than a brake piston, a hammer shaft length gives good leverage, a hammer can be used for many things, a specialised tool for only one.
" Pushing the piston in with the handle of a hammer"  suggests that a degree of force is required.
Quote from: Carolyn on May 15, 2021, 20:29Is the nipple on the back of the pad pined up?
That isn't relevant just now, which is why I didn't answer John above. The outer edge of the pad plate is solid, no 'cutout' sort of thing that the piston segment would slide into.
I tried taking a pic of it, but it wasn't worth posting.
Quote from: Gaz mr-s on May 15, 2021, 21:25
There isn't a "cut out" on the pad, there's a raised bump that slides into the recess on the piston, which is very relevant if you want your handbrake to work...
Quote from: Call the midlife! on May 15, 2021, 22:17
Give me some credit John....
The caliper with piston protruding is giving insufficient room to move over the pads & disc width.  As it happens the piston is pretty close rotation-wise to the correct position, but the outer edge is butting on the pad plate.
Tomorrow I'm going to wind back the other piston & see how far it goes in in comparison.
Chilli Girl
 :o Come on now John's only trying to help - It's frustrating when things don't go to plan, I know! Tomorrow's another day and hopefully it will be sorted. ;D
Quote from: Gaz mr-s on May 15, 2021, 20:08Piston come to a stop, will not turn clockwise any more, but is sticking proud of the rubber seal by about 2mm.
Grumble...
 Have you compared it to the other caliper. Thats what I would do to see if it is in anyway abnormal between the two if its not going all the way in for clearance.
Edit: just read your last post. You are  on the right track.
Mr2paul
They should at least wind back to a flush position shouldn't they ?
I'm not doubting Gav here, I'm thinking summat maybe faulty ? It's an easy job, but this is a new part so may not be correct ?
Learning is good. Failing to learn is not an option
Quote from: Gaz mr-s on May 15, 2021, 22:32
It's not a question of giving anyone credit, it's about filling in the gaps for anyone less experienced with the technology using the forum as a search tool.
New users finding  the forum from a Google search on the handbrake might get confused by someone stating that the orientation of the pads and pistons isn't relevant.
