Exhaust blowing
Started by CB 1971, May 10, 2021, 20:36
CB 1971
hi all,
Last couple of weeks noticed exhaust blowing got original toyota manifold and original toyota cat  pipe,pre cats were removed years ago ,had a look and can't find where its blowing are the original cat pipes known to corrode,another question if I replace with  de cat pipe am I going to  run into problems mot time,
Quote from: CB 1971 on May 10, 2021, 20:36hi all,
Flexis are easy enough to get fixed as they're cheap.
Decat pipe will most definitely cause MOT issues.
Cats2u make a cost-effective full cat replacement that fits well and does the trick.
De cat just isn't worth the hassle imho.
Iain
Would stay away from the decat pipe. Will cause problems come mot, and also no doubt throw up a error code as the post-cat sensor wont be reading correctly. A few have had success tricking the sensor but not worth the hassle in my opinion.
Agreed. I'd go for a 400cell cat if I had to do it again, and I've got a 200cell, not even a decat.
Stock is 800cell I think?
Quote from: shnazzle on May 10, 2021, 21:29Agreed. I'd go for a 400cell cat if I had to do it again, and I've got a 200cell, not even a decat.
If I was Na and stock motor I'd go 800 cell.
I don't believe I would notice the extra 1.5hp or whatever you'd gain.
CB 1971
do I need a type approved cat whats the difference?
Quote from: CB 1971 on May 11, 2021, 20:19do I need a type approved cat whats the difference?
Technically yes but I don't think I've ever heard anyone have issues if it's not.
Quote from: 1979scotte on May 11, 2021, 21:09
Chances are it'll be stolen off your car anyway :)
Rat bastards...
But as Scotte says; genuinely never even hears anything anecdotal about issues with an aftermarket cat. Nobody has the time/money to verify whether a cat was 100% the right type. Not even sure there are rules to specify that.
