Radiator replacement & O-ring size?
Started by Ozzy, October 10, 2020, 15:18
Ozzy
Hi,
So I need to replace my radiator and been looking up how to do it and come across a few posts saying to use the bleed valves from the original radiator and to replace the O-rings with a thicker one as they leak.
Does anyone know what sized O-ring I need?
This way I can get some in advance and make life easier when I do it. Also are there any other little things like this that'll need doing? Read something about maybe needing to block a hose off on some replacement radiators?
Bossworld
Quote from: Ozzy on October 10, 2020, 15:18Hi,
The eBay specials seem to have been revised over the years and no longer have the secondary outlet that needed to be capped off with a stop end and wormdrive clamp
With regards the O-ring - I went through this at length and Carolyn confirmed the size:
6mm ID with a 2.5mm wall.
https://www.mr2roc.org/forum/index.php?topic=64576.0
Quote from: Bossworld on October 10, 2020, 15:50
The " secondary outlet" wasn't noticeable when I installed the after market radiator, but it became apparent after a few years, but not so many miles when I lost all the, new, Mr T long life coolant, as I mentioned in my post on your link.
 The supplier had " no knowledge" of what I was complaining about but if you have heard of this from elsewhere!
Iirc I reused the OE drain valve c/w washer in the new rad and that is still ok today.
Ozzy
