Rear brake disc
Started by David59, September 15, 2020, 09:59
David59
Good morning
I had cause this morning to investigate what sounds like a binding rear brake shoe.
Never look at the brakes since I bought it as I was told it had been fitted with new callipers and pads.
I've noticed that apart from the calliper there seems to be no retaining system for the disc ie if I removed the calliper the disc would pull straight off. There's about 1mm amount of lateral movement in and out on the disc.
I appreciate that possibly when the road wheel is put back on that this holds the disc in but just wanted to check
Regards
David
Quote from: David59 on September 15, 2020, 09:59Good morning
Regards
David
That's the way it should be.  The wheel holds it steady.
David59
Thanks Carolyn...as I suspected
I cleaned the disc up but still catching the pads at one section as I rotate. Suspect it may be the beginnings of run out.
AdamR28
Also sounds pretty normal, rare to have any brake that doesn't touch a little at one point.
