Clutch fluid change?
Started by JB21, August 30, 2020, 12:34
Well that was a faff! Good job you mentioned the rod play Ian as there was none.
Backed it of so there was play and gears were jamming again. Then had to raise the pedal a few turns on the stopper bolt and adjust the rod again.
Don't get the above were it says pedal height to dash panel, as surly its pedal to floor measurement going off the diagram.
Anyways all sorted now. Got around 2mm of rod play and clutch now bites around an inch. Pedal feels at bit long now but will get used to it.
Also took the slack off the throttle pedal by tightening a cable tie around the cable.
Good work and glad i mentioned it otherwise there would of been a post soon about clutch wearing out lol
Hopefully thats it sorted and its not masking some other issue but fingers crossed just needed that tweak :D
