P0120
Started by chalced, August 3, 2020, 11:13
chalced
Hi all,
The car keeps throwing up a p0120 code - TPS fault.
It's running perfectly fine, so is this something I should be concerned about?
m1tch
Perhaps unplug and plug it back in again then clear the code and see if it returns.
chalced
Seems to have done the trick for now, or it may have been that I also gave the MAF sensor a jolly good cleaning while I was in the area !
m1tch
Quote from: chalced on August  4, 2020, 14:48Seems to have done the trick for now, or it may have been that I also gave the MAF sensor a jolly good cleaning while I was in the area !
Get yourself a cheap bluetooth OBD2 adaptor and the torque app and check over the sensors - really handy to have to check codes and O2 sensors and they only cost £3 usually.
