Hood (soft top) adjustments
Started by scm2004red, August 1, 2020, 16:34
scm2004red
Are there any guides for adjusting the hood front fixing clamps to the screen top rail?
My car had a new red twilfast hood last year by the previous owner, and I notice that there is a small amount of movement between front of hood and screen rail on drivers side which closes if a bit of pressure is applied to the top, other side is fine. It feels as though it needs the clamp to pull it down a fraction tighter, Is there some form of adjustment to clamp or bracket?
MR2 Red Edition 2004
Porsche 924 1984
househead
The clamp can be adjusted. You have to open a tab inside the clamp then there is a sort of hex nut that you can rotate to tighten or loosen the clamp.
Kind of hard to explain but if play around with the clamp you'll discover it. When I'm next in the car I'll snap a pic
scm2004red
Porsche 924 1984
scm2004red
For anyone with similar issues very helpful vid makes it simple
https://youtu.be/zcA7LqJSxU8
Porsche 924 1984
