Rear storage bins
Started by Rushy67, July 29, 2020, 18:13
Rushy67
Would someone know where I can obtain the push clips for the side pieces of trim that are within the rear bins. The two removable sections so 4 x clips in total.
A look here  :
https://www.mr2roc.org/forum/index.php?action=search
for " Fixing clips"
Will lead you to here:
https://www.vehicleclips.co.uk/?SID=3e282b9268bb1f9660a2ad00f942da6e
From there it's a process of seek and find.
I would have thought they may need to be genuine toyota ones as they are very specific with the sticky out bits that you can get hold of?
You could try Dick Sloan?
Rushy67
Quote from: Topdownman on July 29, 2020, 18:53I would have thought they may need to be genuine toyota ones as they are very specific with the sticky out bits that you can get hold of?
You are right they are the ones that should be removeable with the bit that sticks up
Rushy67
Quote from: Joesson on July 29, 2020, 18:50A look here  :
for " Fixing clips"
Thanks but as Topdownman says it may mean genuine toyota ones as they should be removable to allow the side trims to be taken out to get the golf clubs in!
There are other similar style clips that do the job if you keep a small, flat blade screwdriver or multi tool in the car, just get some the same diameter for the hole.
