Car shudders on first gear. But only when engine is warm
Started by Dacollecthor, February 27, 2020, 22:44
Dacollecthor
Hi. I have a peculiar problem.
During morning i start my mr2 with no problem. I drive it without any hassle.
But during the day after i have driven it for some time. The shudder starts. But only during takeoff at first gear. When it is already rolling, i have no problem. Sometimes the engine also stalls if i press the clutch.
Why is thenshudder happening only on first gear. And why is it when the engine is warm only and not on the first drive.
Pls help.
Can you elaborate on the shudder.
Just felt through the seat or wheel?
Whole car?
"Sometimes the engine also stalls if i press the clutch."
That is very odd.
Has it been happening for a while or just recently?
Fuel quality change?
I have the same. I don't remember when it started exactly but I put it down to my new engine head steady, as it quite firmly links the block to the body. Also the more solid engine mount didn't help.
Reading this now however, it is quite odd and wonder whether I have the same symptoms as the OP. It only happens in 1st,and only the first time I pull away with a cold engine.
I don't have any running issues and car seems otherwise quite healthy
Same for you?
jonbill
Sounds clutch related. I think a little oil leakage might do this.
Quote from: jonbill on February 28, 2020, 07:30Sounds clutch related. I think a little oil leakage might do this.
I am very much due a gearbox oil change.
I said this last week.
I'll see if I can do this soon-ish and report back
james_ly
Pulling away with too few revs? When it's cold the fast idle means you can't do that.
MR2 gone<br />GT86
Quote from: shnazzle on February 28, 2020, 08:27
Or a tired pressure plate?
Quote from: Carolyn on February 28, 2020, 09:46
Could be, but it's not that old. Granted it does get "used"
Bossworld
May be completely barking up the wrong tree but having replaced the slave and the fluid since I last drove the car...
Found that winding the rod out from the pedal half a turn seems to have made a big difference when it comes to pulling away in first.
Not saying the first two won't have helped, and the old slave clearly had water in the fluid judging by the corrosion around the spring/piston when I dismantled it, but mine was way too close to the floor previously.
