All change for O rings
Started by Carolyn, January 4, 2020, 13:46
For those of us that have bought O rings from 'Sealforce' on Ebay.
They seem to have disappeared.  However an new supplier has emerged.  I suspect it's a re-birth of Sealforce.
Stock is very similar but the shopping experience has changed.
it is now 'Sealssuppliesuk.
Link to Ebay shop is: https://www.ebay.co.uk/str/sealsuppliesuk
If you do buy O rings, I reccommend you save this new one in your 'saved sellers' list.
Bossworld
Hi Carolyn
Would this be the correct up to date listing for the tensioner seal?  Suspect I'm leaking again and I can't remember which o-ring I used when I fitted a new Toyota tensioner.
https://www.ebay.co.uk/itm/Imperial-Viton-Rubber-O-Rings-3-53mm-Cross-Section-BS202-BS261-5-94-171-05mmID/143004596283?hash=item214bbcf83b:m:m1qrhBwYfFRdhxcxkW7VL1Q
Thank you
Quote from: Bossworld on January 19, 2020, 10:05Hi Carolyn
Thank you
Yep.  21.82 mm ID.  Put a smear of oil on it and clean the inside of the housing with some 400 wet'n dry.
Bossworld
Quote from: Carolyn on January 19, 2020, 10:40
Thank you
Thanks I'll grab a few for when others come looking
