O2 sensor thread
Started by Tomo70, January 3, 2020, 20:33
Tomo70
Does anybody out there have an M18 x1.5 helicoil kit going spare. The lambda sensor port on my old cat is in need of repair.
Its that or get a new boss weld into it
Thanks for looking
Quote from: Tomo70 on January  3, 2020, 20:33Does anybody out there have an M18 x1.5 helicoil kit going spare. The lambda sensor port on my old cat is in need of repair.
Thanks for looking
Is that the same size as a spark plug boss? Can't remember what size kit I got to coil up my vvt filter port but if it's the same size you're welcome to borrow the kit, use whatever coils you need from it etc.
Sorry grand fromage, looking back at my purchases its an M14 set..
Tomo70
Thanks for looking John. Much appreciated  ;D
Quote from: Tomo70 on January  3, 2020, 21:20Thanks for looking John. Much appreciated  ;D
I was mis remembering from when I ordered the M18 boss for my cat...🤓
Tomo70
Sorted, used a 18 × 1.5 mm tap with a small amount of persuasion plus high temp grease. Problem solved
