Gummed up washer jet
Started by jvanzyl, December 18, 2019, 19:31
Ok so driver's side is not spraying- I've checked the supply line and it's clear. Seems to be in the actual black nozzle piece somewhere...
Any suggestions? There's nothing visible in the pin holes.. is it easier to just buy a new Jet?
Quote from: jvanzyl on December 18, 2019, 19:31Ok so driver's side is not spraying- I've checked the supply line and it's clear. Seems to be in the actual black nozzle piece somewhere...
Try a sewing needle.....
I shall raid the sewing kit...
mr2garageswindon
Wire strand out of a wire brush is handy too.. pull out with pair of pliers...
yeah I worked on it this morning and got one of the two nozzles working.. the other is mysteriously just still not.. so will try again later. Cheers though.
Chriss
If you have a pressure brake bleeding kit you could attach it to one end of the nozzle and hold the other end with your finger, give it a few pumps and something might dislodge, this is what I did with my Supra nozzles when they got blocked.
