Help re-fitting the metal clamp around rubber steering column boot
Started by barchetta_ms, October 27, 2019, 15:50
barchetta_ms
I've just taken advantage of the dry weather and changed the UV joint on the steering column but foolishly didn't make a note of how the metal wire clamp goes together around the rubber boot by inside the car.
Would someone be kind enough to post a picture of how it goes together?
cheers
