PCV and Turbo
Started by shiny, October 4, 2019, 11:42
shiny
Hi
Will this set up provide enough vacuum on a turbo set up?
All answers appreciated.You cannot view this attachment.
Interested in this also, as well as what to do about charcoal canister etc when turbo, im going to be starting my turbo install in a few weeks and the finer details like this i need to look into :D
shiny
I am going to put a one way valve between the inlet manifold the solinoid valve for the tank vent.
Gaz2405
I've completely removed the PCV on my build as well as the canister, tank now vents into the OSR wheel arch via a 2 way breather on an extended piece of 8mm silicone hose.
I was having issues with the tank becoming pressurised with the PCV installed.
Now 2zz turbo. Home built and home mapped
Quote from: Gaz2405 on October  4, 2019, 12:37I've completely removed the PCV on my build as well as the canister, tank now vents into the OSR wheel arch via a 2 way breather on an extended piece of 8mm silicone hose.
Thanks for info, what have you done with PCV on rocker cover just left it open ?
Gaz2405
Iirc rocker cover vent nearest to you as you look, that's just got a 1 way valve in it and goes back to its original position.
The other breather has a filter on it.
I'll double check tonight as it's a while since I did them.
Nvy
Quote from: Gaz2405 on October  4, 2019, 13:39Iirc rocker cover vent nearest to you as you look, that's just got a 1 way valve in it and goes back to its original position.
Can you couple of pics? Ill be doing that(turbo install) soon enuff too.
shiny
Isn't that the vsv? Correct me if I'm wrong
Gaz2405
Quote from: shiny on October  4, 2019, 15:42
It's been a long day.... And a long time since I did it. Will check when I'm home
Gaz2405
Quick Google, yes I removed  the vsv.
Pcv has a one way valve installed.
shiny
Can anyone confirm my sketch will be ok please?
Gaz2405
I would say yes, but I would remove the top one way valve and just have it venting to air through a filter.
Gaz2405
Right here's  my set up.
PCV has one way valve which you can see then routes back the original way, putting your catch can before this shouldn't be an issue.
You can also see the small filter I've got coming off the other breather, and you can see the head of the large bolt I've used to block of that hose on the other side.
You can also see the small threaded bolt I've used to block off where the vsv used to go, the blue silicone hose then just goes to my boost gauge sender.
It needs tidying up, but its one of those things I'll probably never get round too because it's not effecting performance.
shiny
Quote from: Gaz2405 on October  4, 2019, 19:00
Thanks for the reply Gaz.  I have the small filter on the rear of the cam box and blind cap on the throttle body
at the moment,just wondering whether the one way valve option would give more vacuum for the oil return.
