ECU Master DET3 ok to use with stage 1 Cams on 1zz?
Started by Mikeymead, July 6, 2018, 14:50
Mikeymead
So as the title suggests, Would a ECU Master Det3 piggy back be enough to use with stage 1 cams or will I need a standalone Ecu?
Stg1 doesn't even really NEED any ecu changes. But definitely better.
So yes, it'll add some value
Mikeymead
Quote from: shnazzle on July  6, 2018, 16:56
So how about if you added high compression pistols into the equation?
Quote from: Mikeymead on July  6, 2018, 20:30
I would back away, hold my hands up and say please don't shoot
Mikeymead
Whoops, auto correct strikes again, obviously ment pistons :-[
Quote from: Mikeymead on July  6, 2018, 21:02
Haha. I know. Having a laugh :)
I wouldn't make big changes like that without at least a piggyback like DET3. But at that point you're changing your volumetric efficiency quite drastically so I'd be tempted to go down the route of standalone
Mikeymead
Yeah, your not the first to tell me this, I think at this point it's going to get a bit too complcated and costly for me. Maybe I'll just rebuild the spare engine with the cams and sell the pistons on, I only got them as I placed a cheeky low bid on ebay and only went and won it.
Quote from: Mikeymead on July  6, 2018, 22:01
Certainly not a lost cause. You could maybe use a thicker head gasket to bring them closer to stock compression. (bit out of my depth there and all).
Higher comp would mean cams, valves, springs, your vvti map would be out of sync, your idle would be all over the place. You can see how it quickly becomes standalone territory.
And for what? 2zz is 11:1 isn't it? And that's only 190hp even with a lift cam! So, mid 180s tops? It's definitely a big bump and a lovely one at that, but that's a lot of dosh for a bump when the same dosh will give you a solid 200+ through other means.
