Turbo’d intake temps and tips
Started by dan944, June 13, 2018, 15:41
0 Members and 9 Guests are viewing this topic.
dan944
Firstly...NO CHARGE COOLERS ALLOWED.
I would say a charge cooler is undoubtedly the best option for the mr2.BUT, due do various constraints, normally financial, people choose a simpler intercooler.
The idea of this post is:
To get comparisons of intake temps from as many different set ups as possible.
To help others reduce theirs.
To see if we can compete with charge coolers for a fraction of the cost.
So, to start things of I'll go first.
38 degrees@70mph , cruising, ambient 21degrees.
Boosting around this went up to about 43.
I have a Toyosport intercooler, 550x140x64mm, located under the rear cross member at an angle.
Only attempt at cooling is an ally scoop that sits just lower than the subframe.
Have recently purchased more ally for a heat shield and another scoop(top secret for now), a turbo blanket, exhaust titanium heat wrap and a 9" fan for the bonnet lid. I'll be posting the results I get when I get home to fit them!!
Honda CR-V The Work Horse
@HereComesTheWife sits at a cozy 53deg at boost with 22deg ambient, using the TTE intercooler on SP240 kit.
Not good.
Cruising at 41-45deg intake temps.
Pending Dan's guinea pig work before we come up with a plan of action
SuperArt
Quote from: shnazzle on June 13, 2018, 15:51
Not good.
Is that above the halfway mark on the water temp gauge? I have no way of knowing how warm it gets back there apart from that gauge.
Best regards,
Arthur
That's water temp Art!
We're talking intake temps. There's no gauge for that unless you load up Torque
Quote from: SuperArt on June 20, 2018, 19:09
Not good.
SuperArt
😂 that's what I mean. That's the only temperature gauge I have in the car.
Does intake temp not correlate to water temp at all?
Best regards,
Arthur
dan944
Quote from: SuperArt on June 20, 2018, 19:14
[emoji23] that's what I mean. That's the only temperature gauge I have in the car.
Nahh. What're temp should only fluctuate 1-2 degrees once up to temp. Intake temps can vary a lot depending on the thrashing she's getting.
Or heat soak at stationary.
dan944
Anyone heard anything about these?
I'm thinking the air wouldn't be in the pipe long enough for it to take any effect?
Agreed. Might work for oil or water but not air. Especially not on boost. Unless you had liquid nitrogen surrounding the pipe
dan944
Quote from: shnazzle on June 20, 2018, 20:04
Hmm. Liquid nitrogen jacket? Too far?
BahnStormer
Quote from: dan944 on June 20, 2018, 20:21
...and charge coolers aren't allowed?!?
methinks you've lost sight of the end game!!  :P
Mine is for a daily driver, that WILL sometimes sit in traffic shortly after a reasonable thrashing, it will then be called on to boost again and deliver power reliably, so I've decided to save a few more pennies and only turbo it when I can afford the (£700-ish extra?) for a chargecooler too... I'm hoping to get ballpark 200-220whp, so slightly up on the entry level turbo (probably 180-190whp), I know chargecooler setups usually go for 250whp and more, but the main thing for me is that it is comfortable getting there all the time - I'm driving the car on the road, not on a dyno, so no point in being able to get the power on a dyno (for bragging rights?), but then unable to actually get that on the road without cooking the rear quarter of the car or making things break.
dan944
Quote from: BahnStormer on June 23, 2018, 07:27
Hey!!! No charge cooler allowed.
The idea was just for people find a the best intercooler set up or how to reduce their temps. There were a few other reason i don't want to chargecool yet though
I'm decently sure that with everything you've now done, Dan, you've got a good setup.
dan944
Quote from: shnazzle on June 23, 2018, 08:46
I'll let you know this afternoon :)
Nvy
Have you thought about behind the wheel intercooler with arch delete or half removed? You will also have to mod the bumper to drive the air out or fit a duct or something like this.
dan944
Quote from: Nvy on June 23, 2018, 10:50
The thing isn't intercooler is 650 mm total length plus pipework either end. I wanted max flow from the length. I think I should get some decent flow through it with the scoop. We'll see.
dan944
What's ambient?
It's 24 degrees in my house today.
dan944
Quote from: 1979scotte on June 23, 2018, 17:59
What's ambient?
24 ambient. 51 degrees under boost. Not managed a motorway cruise yet though :/.
dan944
Motorway drive this morn.
Ambient 11 degrees.
70mph 27 degrees.
That's a 4 degree drop in average temps. Not hugely pleased. Wanted more really. Might revisit once it's mapped properly.
I wonder whether having the fan there is actually making it worse at speed.
Can you remove it and try again?
We tried to put the turbo blanket over the teeny tiny t2559 and couldn't get it on. Was hoping to present a bit data for this thread as we have a long drive this weekend.
dan944
Really! I feel bad is I recommended it. Mine was tricky to get on but it fits on fairly well. The old manifold bracket was in the way for my and I need to get it on the ramps to take it off as the bolts are solid.
The fan isn't running at the moment but I see what you mean. Causing an obstruction of airflow?
Quote from: dan944 on June 25, 2018, 10:26
Don't feel bad! It's a good looking bit of kit but the way the turbo sits on the SP240 kit just doesn't seem to lend itself to a turbo blanket. Will keep trying though. I think I can get it on from underneath the car.
And yes, obstruction to the usual flow of air out of the bay through the top grill
dan944
Ahh I see. I've no experience with blankets but that one does seem alright. Pity about the fitting.
I had to take the sprigs under the wastegate connecting rod to stop It fouling.
The next drive I have will be to Cambridge so unless I do a test run before then I'll have to just roll with it.
I might do a test run though just to see how it is affecting it.
Quote from: shnazzle on June 25, 2018, 09:50
Bugger I remember not being able to get mine on either.
Thought I was just being stupid.
Quote from: dan944 on June 25, 2018, 11:33
If it were using a MAF I wouldn't worry at all. But because he'll be putting together a VE table, it's very dependent on IAT. If he puts the VE table at a base temp of 40 degrees, it can run into some issues when ambient is a lot cooler.
Mind, there's a lot to done with the IAT compensation tables. So it's not the end of the world.
Quote from: 1979scotte on June 25, 2018, 13:41
The turbine is flippin tiny on that turbo isn't it? Such a shame haha. Cute little thing
