Alignment specs
Started by FuZZy_gr, May 31, 2018, 17:09
FuZZy_gr
Hello fellas i am going to get my car an allignment and i want to ask if anyone has the allignment specs so i can tell the mechanic that will do it. I got 17' wheels rest is oem. Thanks
Quote from: FuZZy_gr on May 31, 2018, 17:09
Any place with modern equipment will be able to look the standard settings up on their database, so you should be ok to just drive up.
Fuzzy.
What^^^^said.
But, that will be with stock wheels.
Still a decent starting point but with 17s won't be quite right.
Quote from: Ardent on May 31, 2018, 18:16
Fuzzy.
What^^^^said.
Yeah but let's face it Jase, the standard settings are so wide you could drive a mk2 through them [emoji38]
FuZZy_gr
Well i ll go with the stock specs and see
Do yourself a favour and ditch the 17s.
Well that's the elephant in room sorted.
The view on 17s is a bit marmite on here.
I'm with Scott. Ditch 'em.
FuZZy_gr
well i had hell of a time trying to find em. not gonna put those little cart wheels back.
Quote from: FuZZy_gr on June  2, 2018, 12:59
Each to there own.
