Can Anyone Identify these injectors?
Started by Essex2Visuvesi, March 1, 2017, 21:05
Essex2Visuvesi
Have the code 23250-27020 1KG on them
They were in the box with the turbo kit
Any ideas what they are from and the specs?
Look like stock injectors from memory.
Stock:
I had the colour right, at least!  s;) ;) s;)
Look the same to me.
Essex2Visuvesi
The numbers are different tho... not sure if it makes a difference
They're  Denso injectors.
210cc/min at 43.5psi.
12 hole?
 m http://m.dhgate.com/product/one-year-wa ... 3122295942 m
Essex2Visuvesi
Can't see this time of night lol
But I think so....
No good for a turbo conversion then really
Theres a set of 2ZZ yellows as well
My 440cc are good for 240bhp
550cc i think are the biggest you can have if using a piggyback ecu. Sure i read it on here somewhere.
Essex2Visuvesi
Quote from: "1979scotte"My 440cc are good for 240bhp
Running a PFC with charge cooling and water injection.  I'm on stock internals so aiming for about 5-7PSI
Which should I use... these or the 2ZZ yellows?
either way I'm sending them to injectortune for a service and flow report
What turbo will you use.
My t25 makes 11psi and puts out 235bhp.
I imagine with something a bit bigger you will make the same power with less boost so will need the 2zz ones at a minimum.
No point having charge cooling and water injection without the fuel to put it to use.
Essex2Visuvesi
The turbo is from the Power Enterprise Turbo kit which is a IHI turbo
The original setup used stock injectors and run about 4PSI
Quote from: "shnazzle"They're  Denso injectors.
12 hole?
Unless these are different to the standard green ones:
I'm pretty sure they are rated at 270 cc/min.  2zz yellows are 310 cc/min.
I thought stock was 255cc/min haha.
I only said 210cc on these because I found that link, and they look 100% identical and say 210cc.
I don't think the ones I posted the link for (and by the OP) are stock.
They're the injectors for the 1.5L so, I'd assume smaller.
Basically what I'm saying is that according to that link, those injectors are utterly useless to you stock or turbo
