De-cat chamber removal.
Started by ScotMR2, November 30, 2016, 19:20
ScotMR2
Hi. When I bought my 2005 MR2 four years ago, I immediately de-catted it. I was disgusted with what came out and assumed the performance would be improved. It wasn't. I read that the chambers ruined the gas flow so no improvement could be expected. Does anyone know what would happen if the chambers were cut out and replaced with pipe of the same diameter as the rest of the exhaust? Shouldn't present a problem but would it be worth it?
ScotMR2
What you'd end up with is a Toyosport manifold or the like  s:) :) s:)  Available on ebay for 90 to 120 quid. Or a lot more for the fancier ones.
But if you have the means to fabricate it yourself, by all means!
shiny
Will the performance improve?
Meh. Marginally. Depending on where in the rev range. Possibly.
MannyUK
Quote from: "shnazzle"Meh. Marginally. Depending on where in the rev range. Possibly.
Could not agree more, the correct response for your first drive with a new header will be 'Meh'.
Buttery biscuit base
