Gasket from exhaust manifold to cat pipe.
Started by Philip0694, May 11, 2016, 13:06
Philip0694
Hi everyone,
I've just brought a toyosport exhaust manifold but I need the gasket from the bottom of it to the catalytic pipe, does anybody know where I can purchase one from? I've tried eBay but nothing.
Regards
Philip
wotugonado
Toyota crush/donut gaskets, don't use anything else they're usually crappy.
Philip0694
Will they work as the toyosport manifold has a different flange compared to the standard crush gasket
wotugonado
 l viewtopic.php?f=11&t=34531&p=414371 l
As your new and I'm in a good mood click the link above  s:) :) s:)
Also top right hand corner search function there's not much that hasn't been covered before.
Good luck with it .
Philip0694
Hi
Thank you, I'm at work so can't search for to long.
Mark A
I had similar problem, the Toyota o rings will fit but it's a pain positioning them as the toyo has a flat surface and no depression to hold the rings in place.
jeffsimply
The cat does though- they won't go anywhere trust me. Just don't overtighten the 3 bolts.
I have tried aftermarket gaskets and even copper exhaust paste. OE Toyota is the only one that hasn't blown for me (yet).
mrzwei
Use a smear of something like Granvill3 Blue Gasket Sealant for a 'belt and braces' job.
Also, tighten everything progressively ie don't torque up the manifold and then the cat, you need to tease a good join.
Ex.MR2 SMT sadly missed.
