Re - mapping
Started by mikeonsea, April 27, 2016, 21:50
Paulus1066
what figures did you get from them? and what did you get elseware?
Quote from: "Paulus1066"what figures did you get from them? and what did you get elseware?
I didn;t get any  s:) :) s:)  My emanage came from robsonic on here, with a very similar car setup. His was dyno'd at 158 by Noble.
Comparing dyno runs from elsewhere is neither here nor there. Really the only use a dyno printout is to compare pre and post map, because the delta is valid regardless of dyno. And of course to see how well they've flattened out the torque curve.
So for that reason, I'd never bother with a dyno run unless I changed something. i.e. when I go to put a sports cat on my car, I will have it mapped again. Ultimately I'll have a dyno done, cat changed on location and mapped, and then dyno'd again under similar conditions if possible
