Standard vs Smaller Steering wheel - Opinions?
Started by Jrichards20, April 1, 2016, 10:19
Jrichards20
Those that have had both standard steering wheels and aftermarket smaller ones, what have you preferred for non-track use?
The reason why I changed to a smaller steering wheel is because I thought the standard one was too big. And when on track using a smaller wheel was so much better. But seeming that my car is going to be more of a road car, does the different driving style effect the feel of the wheel?
I've got meisterR coilies, adjustable polybushed arbs, adjustable polybushed arms, ad08rs, so the ride is going to be harsher than normal. And the steering wheel tends to feed you that harshness. Do you think that the size of the steering wheel wont matter so much as a) it'll be on the road so wont be bothered by a larger steering wheel and b) a larger steering wheel will reduce the harshness transmitted through the ride?
Street Triple 765 RS
Josh is doing it again.
Mate is it a track build or a touring build?
brettfield999
Subscribed, I also am interested in people's responses to this topic, the wheel (for me at least) is a little too big and far away so It keeps getting my thighs, i'm only 6ft and not a fatty; it seems like it was built for a smaller driver
[strike]2000 Blue PFL MR2 Roadster with 187K, engine blown[/strike]<br />[strike]2000 Blue MRS, 80K[/strike]<br />[strike]2001 Blue PFL MR2 Roadster 131K, 2ZZ,[/strike]<br />[strike]2003 Silver FL MR2 Roadster with 81K now daily driver, 2ZZ by Headcase[/strike]
Jrichards20
Quote from: "1979scotte"Josh is doing it again.
Touring!! Definitely touring! I hate myself sometimes   s:lol: :lol: s:lol:  always bloody changing my mind.
Definitely touring!
tomaky
You sure? i know you had a elise but with the poly's, coilies, yoko's the ride cant be comfortable for touring.
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
Jrichards20
Quote from: "tomaky"You sure? i know you had a elise but with the poly's, coilies, yoko's the ride cant be comfortable for touring.
Nope not sure, never bloody sure  s:( :( s:(
I think the best bet is to create something very similar to Rogers turbo. That had standard suspension, but it also had much larger wheels. So I was hoping that with the coilies on soft setting but smaller wheels with a bigger profile should create a similar ride? But on the odd occasion that I take it on track I will b able to up the damping and ARBS and it should perform relatively well.
Just wondered whether the steering wheel would have much of an effect of driving feel? I think someone else needs to start making the decisions for me, because clearly I cant    s:cry: :cry: s:cry:
J03
A 320/330mm steering wheel is ideal, the stock wheel is like something from a bus! Any smaller than 320mm however & it feels very silly. I would also recommend an extending boss, so that it can be adjusted to sit closer to you. That small amount of adjustability makes a massive difference.
tomaky
Quote from: "Jrichards20"
Id sack the poly's off, i wouldn't go bigger than 16" regardless of wheel size you have to get the tyres right, as you know the yoko and r888 have side walls made out of pure rock haha. I will eventually daily on coileys and the sp's but only on t1r's as they help the ride no end. For track it'll go to my pre fl which will prob be replaced with fl's.
Westfield Seiw
Ex - 2003 Sable
I think polys was a step too far for a touring build.
Why dont you go with your heart forget the v6 and go full track 2zz.
Jrichards20
Id sack the poly's off, i wouldn't go bigger than 16" regardless of wheel size you have to get the tyres right, as you know the yoko and r888 have side walls made out of pure rock haha. I will eventually daily on coileys and the sp's but only on t1r's as they help the ride no end. For track it'll go to my pre fl which will probably be replaced with fl's.
Problem is, the rear arms are all aftermarket so they all have standard polybushes, so cant really replace with normal bushes. ARBs are whiteline adjustable, again polybushed. Really not sure I can bring myself to sell all the suspension items i've just upgraded because they've got polys lol  s:( :( s:(
No definitely not going bigger than 16''. Got PFL wheels at the moment. Next year was considering the enkei RPF1s 15/16. Just so I can have some wider rubber on the back.
Hmm, you could be right about the tyres. Maybe if I find a softer sidewall it will help. I wonder what tyres are out there inbetween the T1rs and the ad08rs in terms of sidewall stiffness.
Jrichards20
Quote from: "1979scotte"I think polys was a step too far for a touring build.
I can go off you.. you going to by the V6 off me for cost?   s:lol: :lol: s:lol:
No.
If i am totally honest mate i still think you want an elise.
Swan_Connery
I use a 300mm wheel on mine. Although a small wheel I'm a big guy and need the space under the wheel for my legs. Very direct input though.
mrzwei
One of the main criteria of the size of the steering wheel was the ability to turn from lock to lock without taking your hands off of the wheel.
I could do this in my MGF and just about in my MR2 (larger wheel, oh shame   s:lol: :lol: s:lol:  ) but not quite in the Golf.
So a competition thing really.
Ex.MR2 SMT sadly missed.
martin_b
Quote from: "mrzwei"One of the main criteria of the size of the steering wheel was the ability to turn from lock to lock without taking your hands off of the wheel.
As Above..  I've gone to 320mm Momo to achieve the lock to lock test.  With the added advantage that it feels much nicer to the touch.
"Anyone who is not shocked by the quantum theory has not understood it."  Neils Bohr.. Attributed
