QRP Axles? Alternatives?
Started by manos3003, March 22, 2016, 20:50
manos3003
Hi guys,
Doing healthchecks on the car before its MOT I noticed an ever so slight weep from left halfshaft. I'm 2zz-ing my car within the year and I think halfshafts should be on my shopping list.
I've seen QRP from MWR, so thinking on it. Anyone has any other suggestions?
I can't recall a day when I drove my MR2 and it didn't put a smile on my face
<strike>2000 Spectra Blue Mica - 2ZZ-GE gone, but not forgotten</strike>
2002 Spectra Blue Mica K20A2 coming up
manos3003
Bump!
cabbydave
Most you might need is 6 speed standard drive shafts
manos3003
Quote from: "cabbydave"Most you might need is 6 speed standard drive shafts
 Considering I've got a 5-speed, they will need swapping then.
Cheers Dave!
cabbydave
5 speed ones work fine so no need to swop them
manos3003
Quote from: "cabbydave"5 speed ones work fine so no need to swop them
Since mine are failing, I'm thinking it's best to swap them rather than refurb them...We'll see...
Mark A
What do you mean failing? The seals on the box or the CV joints
manos3003
Quote from: "Mark A"What do you mean failing? The seals on the box or the CV joints
Ehm, both  s:shock: :shock: s:shock:
manos3003
Right, did some more digging, I've discovered it's more worth refurbing my own rather than buying the QRP ones. I should be looking to do that when the car is apart getting prepped for the swap.
