Full rollcage and underbrace
Started by secla, March 21, 2016, 13:34
secla
I just got one of matts last underbraces but I'm debating whether to fit it or not as I intend to get a full weld in cage next winter, will the cage make a underbrace a bit pointless ?
J03
If you're hitting the track I would say every little helps. On a road car however, stiffer isn't always better.
Jrichards20
The full cage would probably make the underbrace effect negligible, but cant say for sure. Best bet is to fit it for the moment as it will help until the winter (if your driving it in-between). Then once you've got the cage in, you can experiment with the brace on and off. If its kept in good condition and you find you don't need it once the cage is in, im sure you will be able to sell it on.
Street Triple 765 RS
secla
Definately track, it's not a road car
Yeh I guess I may aswell fit it
As above... Try it and sell it if it does nothing.
 It makes a hell of a difference to the cars (without roll cages) so if you don't notice anything, might as well share the wealth  s:) :) s:)
secla
I was just considering the fact it's brand new and there not made anymore it's probably worth what I paid for it.
But I've got a whole summer of trackdays before the cage will go in so I guess for the £ it will lose will be made up in the performance through the summer
Quote from: "secla"I was just considering the fact it's brand new and there not made anymore it's probably worth what I paid for it.
Not being funny but as these are not being made anymore by Matt, you might lose a 10 er tops  s:) :) s:)  Even with scuffs.
It's a collectors item now haha
hamspeed
It will also depend on the cage design and installation, seam-welding and adding additional gussets will obviously help a lot. If you aren't bogged down by red tape or regulations for a specific series then go wild!  s:D :D s:D
02' Toyota MR2 Roadster Race Car -
Owner @ GarageFiftyNine - Supplier of Automotive parts and accessories | Stainless Steel Manifolds | LED/DRL Fo
secla
the only things i have plans to enter are time attack or totb
which are pretty much unregulated, although certain things will bump you up into a different class
