Being as amazing as we are, the Committee has decided we've outgrown our hosting, so we'll be moving to a more capable host with more capacity and space soon! Stay tuned for the down time.
2zz Oil Pump Gear Change
This Forum contains how to guides written by our members. Access is restricted. Only Admins can post here.
User avatar
manos3003
OBD2 Code Reader?: Yes
Postby manos3003 » Tue May 30, 2017 8:34 pm
Right, we all know that 2zz engines suffer from pump disintegration due to resonance frequencies doing their magic at high rpm, usually over-revving scenarios.
There is two ways to fix it; one is to upgrade the sintered gear in the oil pump with a billet one and the second is to change the crankshaft pulley with a Fluidampr or another harmonic dampening pulley spec'd for a 2zz engine. They're almost mutually exclusive solutions, and I chose the oil pump gear upgrade for two reasons:
1. I had purchased from Toyota a new pump to install
2. I had already purchased from Eliseparts an oil pump gear :lol:
This is how I did it and found it the best way to replace the gear without causing damage to the Philips screws holding the pump shell together.
Apart from a new Toyota oil pump (recommended, as any aftermarket billet gear is machined and toleranced against brand new assemblies) and a billet gear of your choice (Toda, Eliseparts, MWR etc) you need the following tools and process steps to complete the job.
Tools
1x long ratchet (you'll need all the torque you can get!)
1x suitable adapter for screwdriver bits for the ratchet
1x hammer (YES! HAMMER!)
1x vice ( in a pinch, a friend holding the pump can also help :lol: )
1x the biggest/fattest Philips screwdriver bit in your kit
Process Steps
  1. Start by placing the screwdriver bit on the screw head and hit it hard with a hammer until it's solidly in place.
  2. With the pump secured on a vice (or with a help of a friend holding it completely flat), attach the ratchet and rotate counter-clockwise to undo the screws
  3. Remove sintered oil pump gear and replace with billet
  4. Assemble the pump and tighten the bolts as much as practically possible (avoid damaging the bolts heads)
It's a quick job, the only tricky bit is those Philips screws holding the pump together.
I hope you find this useful. Any questions on this, fire away :)
You do not have the required permissions to view the files attached to this post.
2000 Spectra Blue Mica - under development
For more info, have a look at my build thread
User avatar
MR2ROC Affiliates & Moderators Manager
Re: 2zz Oil Pump Gear Change
Postby shnazzle » Tue May 30, 2017 9:30 pm
Thanks Manos!
I'll put this in the How To section
2005 Sable MR2 ...neutiquam erro. Honorary wearer of Pants of Shame 2015, for TWOCing
Reader's Ride link
Return to “How To's”
Who is online
Users browsing this forum: No registered users and 1 guest
