Gas strut to bonnet and boot lids
Started by kwnelson, June 20, 2020, 01:43
kwnelson
Hope you'r all safe out there, running out of things to do, thought I would fit gas struts to bonnet and boot lids!    Thing is I can't find any information in "how to" and therefor would like someone who has done this to offer guidance, ie where to buy, size, strength, how much to pay, guide to position on car, I would like to fit only one under each hood,etc,etc.    1   2   3    GO.
Silver FL 2004 bog standard with TTE,.   H/T On    S/T Perfect
Bonnet Trunk (Front) Lift Support Damper Fit Toyota MRS Spider MR-S MR2 00-07
If you put that into a search on Fleabay you should find a set for around £65 and the option to buy a rear set for the same money.
I can't remember if adding the actual link is within the rules but can do if it is.
I'm confident others have sourced their own individual parts for less money so hopefully they'll share with you.
I don't think you'll get away with just one strut though due to the weight of the components and the relatively slim rams required to fit in the space available.
Gaz2405
I've just fitted these, dead simple to fit, they sell front and rear options.
https://www.ebay.co.uk/itm/172355925621
Now 2zz turbo. Home built and home mapped
Quote from: Gaz2405 on June 20, 2020, 09:28I've just fitted these, dead simple to fit, they sell front and rear options.
That's the link I couldn't remember if I was allowed to post or not.😆
J88TEO
I have both front and rear fitted.
