front plastic under tray
Started by CB 1971, April 29, 2020, 12:28
CB 1971
hi all,
how easy is it to remove front plastic under tray is it held on with metal bolts like rear or plastic fixings ,
Essentially easy to remove, assuming the screws all come out, a combination of 10mm hex head machine screws, coarse screws and probably a selection of cable ties.
Just bear in mind if you're jacking the car up from the front point to get underneath (not really necessary though) that the jack will pin the tray in place.
