Cam cover gasget
Started by Smithy, April 3, 2020, 19:35
Smithy
Last time I changed my plugs I noticed some oil on the thread of one plug. I'm guessing that my cam cover gasget is leaking? How easy is this to do myself?
03 Astral black MR2 OEM+
A doddle.  Don't buy the very cheapest, I've seen a couple that didn't quite fit properly.
Take your time, it's a very nice and satisfying little 'first' engine job.
A long 10mm socket and away you go.
You have to remove the plastic cover, then the coil packs and their wiring rail, pull off two hoses, and then unbolt the cover.
Smithy
Thanks for the quick response Carolyn. How much should I spend?
Nice and easy.
Take your time. Remember to clezn up the mating surface and clean out the groove the new gasket sits in.
In june 19. Toyota unit price was £16.39
Code number T11213-0D030
There is no specified torque setting for the doing backup. Just wants to equal and enough.
Smithy
Thanks so much for the information. This forum never ceases to amaze me just how helpful you are. Stay safe everyone
