Time to tinker
Started by Carolyn, March 16, 2020, 15:38
David is over 70 (and some),so we're pretty much self isolating,with just me doing the shopping.
So it's tinker time!  Got to stay busy.
I decided to inspect and lube my handbrake cables, while replacing the rubber boots that were in tatters.
I used the boots suggested by Gaz MR S.  Don't know how he got them on, but I slit mine open and used some of my special rubber glue to close them around the cable.
I disconnected the cables from the calipers, hung them down, and out came a fair dribble of water. Not good!  Cables were running freely, still.  I let the water drain, worked the cables in and out until they were dry, and then dribbled some light machine oil back in.
Did the brake pedal dance while the cables were disconnected, and I felt the pedal firm up ever so slightly.
All back together now and a very good handbrake effort.
Now... what to tinker for tomorrow??
Quote from: Carolyn on March 16, 2020, 15:38David is over 70 (and some),so we're pretty much self isolating,with just me doing the shopping.
No more rattly exhaust?
Quote from: shnazzle on March 16, 2020, 16:24
Now that you mention it.....
paulj
Brake Fluid
Gearbox Oil
PAS Fluid - to name but three liquids with an expiry date!
Today
In the late 1980's
Quote from: paulj on March 16, 2020, 17:45Brake Fluid
Gearbox Oil
All done recently.. But keep 'em coming!!
I can empathise Carolyn being in David's age bracket and apparently " elderly!
You may be aware of my "Thoughts" thread and here is today's offering that pretty much sums up what you say.
In times of great stress or adversity,
it's always best to keep busy,
to plow your anger and your energy
into something positive.
Lee Iacocca
Can I vote for tinkering with the supercharger mr2?
Quote from: jvanzyl on March 16, 2020, 19:42Can I vote for tinkering with the supercharger mr2?
I was going to say that.. But I know better :)
Yes you can.  We've been doing a bit on her. Jonbill has some ideas....'working from home'???
Quote from: Carolyn on March 16, 2020, 20:13
We could do remote tuning hehe
HereComesTheWife
You could make one more super, duper brace for a very nice friend  :)
Quote from: HereComesTheWife on March 16, 2020, 21:00You could make one more super, duper brace for a very nice friend  :)
Not quite that simple.. I have to special order the steel!!  That's why I do them in batches.
But you're on the list for next time!!
Pull the arch liners and remove all the accumulated crud and bird's nests?
Quote from: Carolyn on March 16, 2020, 15:38I decided to inspect and lube my handbrake cables, while replacing the rubber boots that were in tatters.
/quote]
Well, I'm not a lot younger, & the memory isn't what it was.....so I can't remember!  I do have a tool for expanding rubber sleeves, but it's not really made for the diameter's involved.
I think I might have cut off a narrow neck, but not certain.
I wouldn't have suggested them if I'd cut them open though.
A few seconds more thought....different sizes of cable ends?  Mines a PFL, - I don't know if the cables are the originals or not. I think the ends that the clevis pin goes through are approx 13-14mm across.
househead
Quote from: Call the midlife! on March 16, 2020, 21:51Pull the arch liners and remove all the accumulated crud and bird's nests?
That's a good one. I'm sure I hear odd pebbles and stuff rattling around in mine.
Rattly exhaust being dealt with.
Spare OEM backbox in and spots of corrosion in the area treated and painted.....
Newbie57
Quote from: Gaz mr-s on March 16, 2020, 22:11
/quote]
Can I get a link to the boots. Mine are completely shot.
Quote from: Newbie57 on April 12, 2020, 12:58
/quote]
https://www.ebay.co.uk/itm/MG-TF-MGF-MG-Gear-Change-Cable-Rubber-JOINT-END-SEALING-GAITERS-NEW-PAIR/122066392968?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
