Front subframe? Urgent Help!
Started by tricky1138, August 7, 2019, 12:56
tricky1138
So car is in garage today getting new front wishbone.
Garage has just rang to say they cant fit it as the "front subframe" has rusted through and needs a new one.
Anyone know if its replaceable? Struggling to find pictures to explain it better! :(
J03
I'm assuming it's the cross member that the steering rack bolts to also? Unfortunately it's welded to the front chassis rails, so you'd need to chop out the rotted section & weld in a good section from a breaker car.
tricky1138
Quote from: J03 on August  7, 2019, 13:19I'm assuming it's the cross member that the steering rack bolts to also? Unfortunately it's welded to the front chassis rails, so you'd need to chop out the rotted section & weld in a good section from a breaker car.
Thought that might be the case! :(
Will get down to the garage and see how much of it I need.
Bossworld
From what I remember there are two upright 'tails', one on either side, that the wishbone is bolted through.
There is another bolt/bushing that goes upright (as you look under the car) but I'm not sure if that would constitute the subframe.
Excellent picture stolen from Stu C
Suspect your issue is A.
tricky1138
Quote from: Bossworld on August  7, 2019, 14:02From what I remember there are two upright 'tails', one on either side, that the wishbone is bolted through.
Cheers Joe - is A the front most?
Bossworld
Quote from: tricky1138 on August  7, 2019, 14:05
Yes - the bit to the right of the picture must be the inside of an alloy wheel,
+1 @Bossworld
My picture is taken from the front of the car looking backwards on the passenger side.
tricky1138
Quote from: StuC on August  7, 2019, 17:17+1 @Bossworld
Cheers both of you.
Been to see the car and Joe is right, it's where A attaches to the car. That bit has rusted through so the bolt won't hold! :(
Guessing big job to cut out the whole of the front of the car and replace the whole thing!  :(
Will any breakers cars be any better!
Bossworld
Quote from: tricky1138 on August  7, 2019, 19:11
Cheers both of you.
I'll admit I don't know the first thing about welding and my soldering skills are also useless, but I'd have a Google to see pictures of the car stripped out of the frunk and see what's necessary from there.
Fortunately you don't have an engine in the way, and once you've taken out the spare wheel well it's not like there's equipment everywhere.
You could also see if the online repair manual (can't link to it) has any guidance as to how far back you need to cut.  Would think Dick or Dean would be your best shout.
As for whether a breaker would be any better - my car is 14 years old, currently lives by the coast, seemingly previously lived in the sea and mine was OK, so there should be others out there.
tricky1138
Didn't think mine was bad, but garage seams to think it is!
Have spoke to Dick and Dean. Just waiting on them checking.
Remember it's a key alignment point. Chopping it out and replacing with a breaker cut-out is asking for alignment issues and weak welds. You're better off cleaning it up, treating, and using new metal on top. Keeps the alignment, holes, structure, etc
tricky1138
Quote from: shnazzle on August  7, 2019, 21:04Remember it's a key alignment point. Chopping it out and replacing with a breaker cut-out is asking for alignment issues and weak welds. You're better off cleaning it up, treating, and using new metal on top. Keeps the alignment, holes, structure, etc
Would have thought if it could be repaired, they would have gone down that route. As you say replacing is a big job with lots of problems!
Quote from: tricky1138 on August  7, 2019, 21:21
Never assume competence and people's ability to see all solutions. As harsh as that sounds
