Steering not self-centering
Started by paulrogers7364, June 23, 2019, 15:10
paulrogers7364
Guys,
I recently had my front springs changed due to one being broken.
I have noticed recently that the steering no longer enters itself.
Anything I can do / check myself before taking it to be checked over?
Sounds like an alignment problem.  Not a lot to do but check it on a rig.
Quote from: Carolyn on June 23, 2019, 17:54Sounds like an alignment problem.  Not a lot to do but check it on a rig.
+1
But one wonders why the change?
Was 2 dodge springs offsetting each other and keeping things straight. Hope so.
Who done the work?
Did you see work carried out?
Done Diligently or bish bash bosh?
james_ly
Do you get any grinding noises when turning? Maybe the spring isn't sat correctly.
MR2 gone<br />GT86
Flibby
This was the primary symptom for me when my steering UJ was on it's way out. Worth checking as the issue with the spring could be a coincidence?
tomaky
UJ certainly will not help with this. Get in there and fire some grease into it and see if it makes a difference. Worth getting a alignment regardless.
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
