Front brake pad shims ?
Started by sussex, June 2, 2019, 18:27
sussex
Could anyone confirm if the front brake pads should have a anti squeal shim on the back of each brake pad as mine does not have any fitted and they squeal when the brakes are hot,  if they should be fitted where can I buy them from, Thanks
gazza1286
They are a dealer only part. I've previously fitted them but some aftermarket pads do not work with them very well.
Personally I wouldn't bother. Using copper grease (or Ceratec) will resolve the squealing problem.
sussex
I used ceratec grease when I changed pads and discs last year and they squeal when hot
sussex
Maybe I will remove pads, clean all contact points and re grease and refit and see what happens
I think there were some of these in the auction at ding day. (Did not sell)
A club contribution  could/might secure them.
Apologies if I'm wrong on either account
Quote from: Ardent on June  2, 2019, 22:15
I had the same thought Jade.
Who took them home?
Quote from: StuC on June  2, 2019, 23:00
Who took them home?
Simon paid a quid for them with the callipers I'm sure?
Sent from my iPad using Tapatalk
ah yes.
I remember somethings but not all things.
Apologies for the false hope.
ManInDandism
Not cheap from Toyota either - £38 for the front ones, so a quid is more than a steal!
Painted my calipers in situ before replacing pads and discs and decided I would just get hold of new ones front and back plus pad holders rather than trying to mask everything off. Might have thought twice if I'd priced up before ordering (rears are a bit cheaper).
4945-20210 is front part number and rears are 4946-17010 and come in at £27.14.
Black 2004 Roadster
Quote from: ManInDandism on June  3, 2019, 09:43
To be clear, these were pre-owned and in need of a good clean so probably only worth £2.50 at a push.
There were bargains galore to be had on the day!
I got them - I think I paid £2 for them.
I was just trying to remember if they were front or rear!
sussex
Ordered some ebc universal anti squeal shims off ebay, you cut these to size and they are self adhesive, get excellent reviews only £5.90 inc delivery for 4
