Screw size?
Started by Call the midlife!, May 22, 2019, 20:51
Screws that mount the RHS drive shaft support to the block, 14mm 1.5? I've lost one, nearly lost another and forgot to check the size before locking up and setting in for the night...
Quote from: Call the midlife! on May 22, 2019, 20:51
M10, I think it's 1.25, but not absolutely sure.  I'll pull one from the blue car later and check.  Got some.
That would make sense as it rattled in an m12 boss earlier [emoji23]
Slightly worrying that I've lost one and half lost another, we're sure "we" nipped them up.
But it's all due a going over at the weekend anyway so they'll go back in with some loctite as looking at the thread on the one that was half out it seems that step got missed.
Ta muchly.
Quote from: Call the midlife! on May 23, 2019, 08:57
Ta muchly.
Yep M10 x 1.25.  The ones I've got are actually flywheel bolts. (12 point heads).  Perfect length and decidedly up to the job.  Want a couple?
Quote from: Carolyn on May 23, 2019, 09:35
Ta muchly.
Flywheel bolts? If that's the case I'm good, ta, replaced mine with ARP ones when we changed it so I'll have the originals in my "spares" box!
And thanks again, again [emoji23]
