What is a markii pipe and what does it do
Started by Stannyman, April 8, 2018, 11:30
Stannyman
Hi
What is a markii pipe and what does it do?. I want to increase the power a little. What about maf ( I have cleaned it and resett the ecu disconnected the battery) but was thinking is there a mod there to make a slight increase. It does a little bit better doing this or might be me but it makes me feel better.
Cheers stanyman
jonbill
It's a replacement air inlet duct, to make more noise and less power.
Stannyman
I like the sound of more noise but less power I would like a little more power really.
Quote from: Stannyman on April  8, 2018, 16:23
Tbh there isn't much power to be released in these cars without spending a considerable sum of money.
Bugster_MR2
Quote from: jonbill on April  8, 2018, 11:59
Is it dyno proven that this mod looses power?
Bugster
2001 red with KW3, TRD rear brace, Zero race cat and MAF-mod.
2003 silver TTE Turbo, underbrace, sidescoops, style bar, front bumper, rear spoiler, interior garnish, exhaust
Quote from: Bugster_MR2 on April  8, 2018, 22:25
I'm not entirely sure jonbill isn't mixing the pipe up with an induction kit/cone filter set up. (If he's not then I look a plum and apologise).
The markii pipe is basically a stainless pipe that replaces the plastic transfer pipe from the side vent assembly to the standard airbox.
The standard pipe narrows and possibly restricts the airflow to the box, the markii pipe is wider/same bore all along so allows a better flow of air.
No noticeable increase in noise and probably very little in bhp but there are proven gains in throttle response.
Quote from: Stannyman on April  8, 2018, 11:30
Hi
Cheers stanyman
Ignore the lawnmower in the background, other than fitting the engine on the 2 it won't increase performance, just noise!
But that's a markii pipe.
mrzwei
For the record, it's a Markiii  pipe and by keeping the pipe diameter the same along its length, it probably shifts the torque curve up the rev range a bit. It's a knock off of an expensive Jap tuning firm alloy design which claimed a performance increase. I think the taper in the original design was to help low range torque but this is not proven.
Ex.MR2 SMT sadly missed.
Just to add to mrzwei's note.
Markiii is a long standing memeber of ROC, who helped develop the pipe for our consumption. Om nom nom 8)
@markiii isn't it about time for another batch? <runs>
Quote from: mrzwei on April  8, 2018, 23:07
Didn't have my glasses on, could've sworn I'd put all three i on...
Quote from: StuC on April  8, 2018, 23:25
I wonder who owns the record for the most times bought and sold? I know I'm at least the third owner of the one on mine.
What ever the exact reason, MrTs R+D section decided that was best. Narrowing generally increase flow speed.
However, my biggest question is. The air is metered staight out the other side of the air box by the MAF.
Which feeds info to the ecu etc etc which controls the fuel delivered etc etc.
The 2zz uses the same filter and air box so lack of flow is clearly not an issue.
Quote from: Ardent on April  9, 2018, 00:19
Not quite the same airbox. It's a bit fancier on the 2zz. But yes, flow is not an issue. Everything from the filter itself onwards is clearly capable of 190ish hp
m1tch
I just ran some brake ducting from the side pipe to the airbox replacing the rigid pipe all together, than removed the stock airbox all together and am now running a filter behind the battery.
