Gearbox LSD - limits?
Started by m1tch, July 24, 2017, 17:01
m1tch
Hi all,
Just working out gearbox options I need to sort for my project, I will be looking to get a C64 box rebuilt with uprated 3rd and 4th gears so that I know the box will be happier at higher torque figures, my question is if I should run with the stock LSD as well - not sure what they are usually rated to. I don't plan to remove the engine and box once the built engine is in so I just want to get it right first time so if the LSD can't handle higher torque then I might run with an open diff.
MilesH
LSD should be fine, I've never heard of any issues when it's run in 300bhp cars.
How much power are you planning on running?
