DIY Intake
Started by GraemeL, November 8, 2016, 08:55
GraemeL
Hi just wanting to get some opinions on this item
  m http://www.treadstoneperformance.com/pr ... a%2C+Lexus m
I've never modded a car but would like to tidy up the air intake using the above adaptor with some 3" silicone hose to take a cone style filter behind the the battery and above the LH air vent. Not interested in forcing the air just having the filter in this colder air area. Opinions welcome. Thanks in advance
2003 FL silver&red leather, a/c and hardtop. Totally standard so far
\'03 Silver FL, Leather, A/C, Hardtop
peppyuk
That might be a touch too big, the standard piping is 70mm (2.75") so I guess the measurements would be off with a larger pipe for the MAF.
\'In a state of mental numbness\'
GraemeL
Thanks for info. I'm offshore at the mo so just passing time looking at various scenarios. I figured the right size MAF adaptor then silicone pipe to filter behind battery would be a straightforward job. Got worried as I looked at various threads and started reading about ECU issues etc etc.
peppyuk
I had a bit of old after market intake left over from an old Celica which I used to mount the MAF.
I got this filter
http://www.ebay.co.uk/itm/351160467084?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
and this hose (needed a 45° bend as the throttle body is slightly angled up)
http://www.ebay.co.uk/itm/252213938355?_trksid=p2060353.m2749.l2649&var=551047166682&ssPageName=STRK%3AMEBIDX%3AIT
The filter sits nicely in front of the battery in behind the side vent. Intake temps stay very low   s:D :D s:D
Oh, and it likes to roar above 4k rpm   s:twisted: :twisted: s:twisted:
ChrisGB
Quote from: "GraemeL"Hi just wanting to get some opinions on this item
Unless you are running some serious level of tune, you are not going to need that in your setup. It has the potential to cause problems with MAF calibration.
