Calling All Power Enterprise Turbo Owners!
Started by Essex2Visuvesi, November 4, 2016, 16:39
Essex2Visuvesi
I need some help!
I need some pictures and measurements of the turbo actuator bracket.
The Kit I have is missing the bracket so it would be appreciated if someone could post up some pics/measurements/fag packet sketch of said bracket so I can get one fabricated?
I tried contacting PE but all email addresses I have found bounce back as undelivered    s:? :? s:?
Which manufactuers turbo is it? EDIT IHI.
For example the TTE turbo kit and the SP turbo kit both use a Garrett turbo found on the Saab 9000.
So the actuator and fittings are just stock Garrett parts and easily sourced.
Or does the way the turbo is orientated/clocked means it uses a custom part?
Essex2Visuvesi
Its looks to be a Hybrid IHI turbo, something like the the RHF5 but I cant find the exact model.
It does look like the bracket is custom as is the exhaust housing as I cant find a gasket to fit either
Peter Wright
Is this the bracket you need, hope the pics work, if it is will try and get measurements tomorrow
Essex2Visuvesi
thanks  s:) :) s:)
I'm getting a 404 error with the pictures tho
Peter Wright
Pics up at last
Same bracket as mine but from the op previous posts his wastegate is different.
Essex2Visuvesi
Quote from: "rbuckingham"Same bracket as mine but from the op previous posts his wastegate is different.
Yes I have this one as the wastegate and bracket was missing from the kit I bought 2nd hand
 m http://shopping.kinugawaturbo.com/kinug ... ation.aspx m
The picture does help!
It looks like the wastegate bracket has a twist in it so the actuator sits at an angle to the housing rather than perpendicular
I think I'm going to have to make one up
