Power FC fault codes
Started by KJPG, October 17, 2016, 18:08
KJPG
Just picked up my Power FC, using this is it possible to clear / read fault codes without the OBD reader? I don't think the guy who installed the 2zz previous to my ownership hooked it up correctly, as it doesn't seem to read on my fault code reader.
Tbh i thought you lost ODB2 function with a standalone ecu.
I am no expert however.
If you have the hand controller you should have access to all the relevant info anyway shouldnt you?
Essex2Visuvesi
The Apexi loses all connectivity with the ODB port, you need to do analysis the through the PFC hand controller
KJPG
Cool, thanks! FYI I haven't hooked up the PFC yet, so surely in that case any fault codes wouldn't go to the dashboard warning lights?
Essex2Visuvesi
I'm now confused as to what you are trying to acheive
vinp182
If the conversion has a JDM celica ecu then the obd2 won't work anyway IIRC
2001 Nissan Silvia S15 SpecR
1993 Rev4 Turbo mk2 300whp
1994 Rev3 Turbo mk2
2004 Renaultsport Clio182
KJPG
Essentially, I have a CEL lighting up on the dash with my current OEM ECU, which is JDM Celica so that explains why that doesn't work. I'm wondering how to go about clearing the CEL once the PFC is in.
Well, you have to disconnect the battery to install the PFC, so leave it twenty minutes, and the cel should disappear anyway. You can get a light from the pfc, but that is normally a warning that something is way off! Not just a bit of a warning!
weeJohn
Fault codes are held in the ECU, so when you remove your stock ECU and fit a PFC the fault codes will clear. You will not be able to read fault codes via OBD2 with the PFC.
When its fitted, the PFC will flash the CEL if it detects knock, or injector duty is at a % level set via the PFC settings.
cabbydave
Do you want the fault codes reading on your jdm ecu?
KJPG
Should be fine dave. Gonna try fitting the PFC later and see if it's got a base map or not.
