swap
Started by schaffo2, August 9, 2016, 07:32
schaffo2
Hallo I'm looking for a complet2zz-ge swap kit for my MR2 year 2000 (with out 6 speed transmission), I would like to re-use my old 5 speed transmission. complet swap kit? Also do you have a light weight fly wheel avalible for the 2zz-ge enigne to my 5 speed transmission? I'm looking for a complet swap kit, with everything needed for the swap like MWR i usa.do anyone now where to look
greatings Jørgen
Reuisng a gearbox from your 1zz roadster will result in an awful 2zz swap. You need the correct ratios from the celica/corrolla donor to keep the engine in lift.
Headscase here sells swap mounts i believe.
I think there is a guy on ebay uk who sells engines loom etc.
Dont think there is anywhere in the uk that sells everything you need.
We have a dedicated engine swap section that would be a better place to ask questions.
mikek
You could try Sam nadeem. Sams t sport spares on ebay or Facebook.  He sells most things for the swap. I got mine from him.
2zz by Rogue. Se7en cams. BMC CDA. Competion clutches lightened flywheel, Megillian Racing Exhaust. TRD sportivo suspension and ARB\'s. TRD braces. TRD quick shift. TRD dash kit, Matts brace. Getting there but not sure when it will stop!
