Janspeed Exhaust diameter
Started by mikek, June 8, 2016, 10:54
mikek
Does anybody know the diameter for the Janspeed exhaust sysyem? If so what is it? Just trying to make sure it will perform well with my engine swap!
Mike
2zz by Rogue. Se7en cams. BMC CDA. Competion clutches lightened flywheel, Megillian Racing Exhaust. TRD sportivo suspension and ARB\'s. TRD braces. TRD quick shift. TRD dash kit, Matts brace. Getting there but not sure when it will stop!
2 1/4 from memory
I can measure later if you'd like?
You interested in the tip size too?
mikek
Mainly the diameter for flow purposes but tip size would be good aswell. Its Going on a 2zz with stage 2 cams and rogue wanted to check the diameter to make sure it will flow properly. I haven't got it yet so it's all ifs ands and maybee's! Thanks for your help
