Cheap Parts Supplier: People have got cheap shifter shafts..
Started by JoeCool, October 22, 2015, 09:51
JoeCool
Dear all:
There was a site posted in one of the 2zz/ 6 speed swap threads with people getting cheap Toyota parts from an overseas supplier with a website that looked very scammy, but apparently delivered cheap parts.... Can anyone link me to it?? I need to find some cheaper bits!
2ZZ '02 Roadster
J03
JoeCool
Thanks!!
Couldn't find it for the life of me, I was reading through all the old threads.
2ZZ '02 Roadster
They're doing rear crossmember for 219 if delivery is less than 100 it's cheaper than main dealer isn't it now cams kill have stopped doing them.
J03
I contacted them about the rear subframe & they can't supply it. Not everything they list is available, you have to submit a request & then see what they come back with. I had same problem with the abs actuator bracket being discontinued.
Pants!
Will just have to bite the bullet and go to Mr T.
Unless anybody knows another route.
J03
I've just sent pics off to a local fabrication company to see if they can put together an alternative frame style design. That might not be to everyone's taste, but I'll post an update if I hear anything back.
cyclehead
Out of curiosity, I sent a note to DD Performance Research in Texas.  They have just started production on a replacement crossmember that should also provide sufficient clearance for 2GR swaps.    I'm not sure what it looks like.  I'm guessing welded tubes?
2002 SMT in Yellow
2001 2GR swap in Black
