List of Geo Set ups
Started by Jrichards20, October 21, 2015, 13:33
Jrichards20
I think its a good idea to have a place to put our geo set ups. I've been looking for some information and cant find it, so hopefully this will grow and be a source of information for people trying to find a good geo. So people can start adding to this list should be a helpful resource!
Example only!
Type: Fast Road
Suspension: BC Coilovers, Whiteline Arbs (second from bottom hole), Hardline rear traction arms.
Wheels: 195/50/16   225/45/17
Weight: FL 208  FR 215  RL 275  RR 282
Front
Caster L 8.05  R 8.34
Camber L -0.28  R -0.23
Toe L 0.2  R 0.2
Rear
Camber L -1.49 R -1.43
Toe L1 .1 R 1.1
Or just post a picture up of the report instead of typing the alignment figures  s:) :) s:)
Street Triple 765 RS
tomaky
Front CASTOR :O
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
lamcote
It would be interesting to know tyre pressures too.
Agreed on the extreme Castor figures, they sound more like Elise values rather than MR2.
Jrichards20
Quote from: "Jrichards20"Example only!
There's a reason why a put this  s:) :) s:)  that geo is from a 996 not an MR2. I don't have any geo print outs of MR2s so couldn't put one up, hence the needs for a list of good ones that people can use as a base  s:) :) s:)  Now stop procrastinating and start adding figures!
Well said Josh.  s:lol: :lol: s:lol:
tomaky
Have to agree could almost do with it separated when people enter there geo to say whether or track or road.
Westfield Seiw
Ex - 2003 Sable
Front
Camber L -1.50° R -1.50°
Toe L 0.00mm R 0.00mm
Rear
Camber L -2.00° R -2.00°
TiM3
Here's mine, track only use;
2001 MR2 Roadster - Cusco front strut brace, Chico Racing shift bushes, soft top delete, 2ZZ-GE, Eliseparts sump, 6 speed box, 4.529 final drive, LSD, custom induction, Zorstec 4-1 manifold, 100cel cat, P&P full cage, RRS 6 points, Cobra Imolas, BC Coilovers (5/7) BattleVersion rear arms, polybushed front arms, poly windows, gutted doors and dash.
PET77
There is some serious camber on the rear:-) Whats you tire size front/rear? Also - out of curiosity - what was the method to get to this specs? Have you used tire pyrometer?
TiM3
Quote from: "PET77"There is some serious camber on the rear:-) Whats you tire size front/rear? Also - out of curiosity - what was the method to get to this specs? Have you used tire pyrometer?
Settings were recommended by my geo guys based on their experience with my car/tyre combo. Currently using 595rsr 205 on the rear, 195 on the front.
Nothing as fancy as a pyrometer (it's only a trackday car after all..) but the back end really does dig in, you can get hard on the power very early, so it works for me.
jaworjawor
it's funny because I have same tire combo and similar geo settings   s:D :D s:D  what tire pressure do you run cold/hot?
TiM3
Quote from: "jaworjawor"it's funny because I have same tire combo and similar geo settings   s:D :D s:D  what tire pressure do you run cold/hot?
Tried just about everything and seem to have settled on about 30psi when hot, I tend to start at 30 cold too and just drop air out as the temps go up (I realise that only works on trackdays!)
