New wheels, will they fit??
Started by Jrichards20, August 21, 2015, 10:19
Jrichards20
After a bit of information, will the following fit onto PFL?
Team Dynamics Pro Race 1.2S
     Front                            -------------------------        Rear
     16x7            -------                           Size                           ---------                             17x8
     ET30            -------                           Offset                        ---------                              ET20
    4x100           -------                             PCD                         ---------                             4x100
     56.6            --------                        Center Bore                 ---------                                56.6
      8 kg           ----------                        Weight                     ---------                               9.9 kg
195/50R16        ----------                     Tyre size                      ----------                          225/45R17
Many Thanks  s:) :) s:)
Street Triple 765 RS
tommyzoom99
hi
the wheels sizes are 1` inch bigger than mine front and rear but the same width, and im running 25 offset front and rear with the same tyre sizes and they fit but did rub quite alot.
you'll need some spigot rings as i think our centre bore is 54.1
i brought a arch rolling tool and had to flare them about 20mm to get them to stop rubbing
there's pics on my build thread in the if you wanna see the fitment and the arches rolled
 l viewtopic.php?f=7&t=51237&start=60 l
cheers tommy
My track project
viewtopic.php?t=51237
Jiff Lemon
Have a look here - Just did the rear!
