Crank/Cam Wheel Teeth?
Started by monsi, July 13, 2015, 18:16
monsi
Hi all,
I'm up to the point of setting up my engine management, please can someone confirm the number of teeth on the crank wheel and the first tooth angle  from BTDC. So far it looks like it has 36 teeth and two missing although I can't find anything reliable about the angle.
The cam position wheel I have no idea about so if someone could let me know what it is that would be fantastic   s:D :D s:D
Simon
[size=85]Sable 2003 Roadster
1ZZ, GT25R, Dual path exhaust, Sports Cat, 440cc Injectors, Chargecooler, Yellowstuff pads, Braided hoses, Custom bracing, Sports springs, Polybushes, Megasquirt - Coming soon boost control and water injection!
[/size]
headcase
Crank position disk. 34 teeth and 2 missing teeth at 225 BTDC Cyl 1 & 4.
4 minus 1 toothed wheel  cam
monsi
Thanks for the quick reply.
I've finished my checks so hopefully tomorrow I'll have her running!
My calibration for the coolant temperature appears to be slightly out, you don't happen to have some resistance vs temperature readings?
Simon
[/size]
